221 - 240 of 1,606 Posts
No, that would be an M90 Super Coupe blower, on the 3.8 SC intake. Not sure how Tom plans for it to work with the carb mounted to the outlet as mentioned.
cheers
Ed N.
Pretty sure that on top of wanting to spin it backwards these blowers aren't machined to run fuel through either.
Hahahaha you're right. Bye bye bearing seals and bye bye rotor coatings!
Although I did see a DIY build on a full size pickup truck where they had the carb plumbed correctly into the rear inlet. The truck was up and running but iirc they did not put many miles on the setup; and then their parents junked the truck while he was away at college.
Not sure what you meant by spinning it backwards, but that is setup to spin the correct way. I think he is planning on using the pumping vacuum of the the engine to suck the fuel and air past the rotors on the outside. Not the most efficient, but it will probably work.
Is there a difference on blowers that are designed for fuel flow through them? I mean, I know these are supposed to be dry from the factory, but they do get a bit of oil in them.
SWS
SWS
Setup to spin the correct way? How so? Ribs on the belt to a ribbed pulley will always spin clockwise. Same as the Tbird SC. However the inlets and outlets are plumbed backwards. Are you going to put a smooth blower pulley on and somehow wrap the backside of the belt around it? Of course not!
The dude ####ed up plain and simple.
Many of the Lightning stock Eaton tuners remove the coating anyway (called stripped rotors)-and then send it to Steigmeier (spelling?) to have it ported. Supposedly there is a 30-50 HP difference. For the seals-don't know how they'd work with fuel. There is constantly oil on the factory Lightning setup though from the PCV system. Very common for guys to remove the IC and clean the oil off of them...and trust me...they get PLUGGED. I pulled mine at 50,000, 100,000 and cleand it. Both times it took I think 14 cans of carb cleaner to get it clean enough to put back in. Lots of oil in there! And it seems like the guys who are complaining about their rotors losing the coating are also the same guys who have an aftermarket PCV and/or breathers. I didn't notice any coating material on my IC when I pulled it out either time I did it. In fact, other than the rotors looking brown from oil vapor, they looked new.
Discussion starter · #234 ·
metalman302 - I used 1/4 inch thick steel plate. Is that what you should use? I dunno, but that what I used because it's what I had on hand. It seems to have worked out pretty well, though - thick enough for structure, but thin enough to be bent flat (with a great deal of force, of course) after welding.
I'm glad to see all the interest in this thread. I do intend to have the car back at the track near the beginning of next season, but as it's been too cold outside lately to work in the garage (comfortably, anyways), I'm taking a couple of months to catch up on other things. In the meantime, if you have any questions, please feel free to ask!
I used 1/4" plate as well. 3/16" just didn't seem to be ridged enough. Great build by the way, I'm now working on an offset setup kind of like yours but on the drivers side like a Kenne bell that can be ran through a front mount intercooler if necessary. Check out my build thread: http://forums.corral.net/forums/showthread.php?t=1251243
also have a for-sale thread that I'm sure some of ya'll have seen. I like seeing all these different options for the 5.0. Alot of creative people out there including yourself.
