ok, if i come across one (or more) ill let you know for sure.haha, well hopefully its the right part.
With there description I wasn't sure if its a 302 crank, or 351w. A 302crank pulley will only be SLIGHTLY larger then my underdrive pulley.
Hopefully its the right one, from a 351, and would love to know the size, and PART NUMBER haha
Sounds like a giant aluminum block would be needed, haha.
Just have a 6rib serpentine belt, not the oldschool V-belt, I'm unsure when they went from the V-belt to serpentine.
Bernie was saying he got his from a Ecoline series van, so maybe thats a better place to look.
If you can find one, I would buy it for sure, but I will be hitting the junkyard one next weekend hopefully
wow, no room at all. doesn't look like there's room to connect the vacuum tube. how is the FPR being regulated by vacuum/boost?Hi Guys just like I promised, here are a few pics of my OEM FPR... as you can see its a very tight fit.. but works just fine.
Bernie.
I'd be happy to give some feedback if I could just get my hands on the adapter.... :idunno:wow, thread has been overtaken! nice! Keep it coming. Now if I could get some people to give some feedback on the offset kit.
The gt40 is the closest or thru on top kit but it will fit WITHOUT the spacer, it was made to fit without it. Guess the rails are closer together on some lowers than others.I'd be happy to give some feedback if I could just get my hands on the adapter.... :idunno:
Joey, do all the kits come that close to the rail/FPR? or is that why the GT40 needs a plenum spacer?
I am trying to fab something up with a tranny cooler and a terminator electric intercooler pump.Im on it! sending payment tomorrow or wednesday
Intercooling - Ive been reading on using my A/C compressor and finding a thin evap core to install in the adapter. The toyota guys have been doing it for years and some lightnings used it... sounds like a pretty simple and very effective way to do it and have consistent intercooling for daily driving as well as the racetrack. Note when your at wot the compressor clutch kicks out so all the haters dont worry about parasitic drag :joy:
you both are on the right track!!
rcrcman, i believe the setup your reffering to is the killer-chiller setup that a the 2nd gen lightning guys use. that would be great if you fab up a similar kit. id definetly be interested in the progress of that.
Thats the same place I looked for a cooler... I think I am going to use it and the electric pump and also the termi coolant tank.I might be going to a tranny cooler also... been looking through hundreds of pages at all the parts stores sites trying to find a evap core small enough to fit inside the intake is proving easier said than done. I found a few tranny coolers in just a few minutes on ebay that will fit... I think that will be the way to go. Have alittle more research to do on using a snake tube style or manifold style and efficiency differences.
I am extending the actual housing mainly for cosmetic reasons because of the longer shaft.What exactly are you trying to do by making the snout longer? are you trying to extend the actual housing?
What pump are you looking into? And what is the size of the transcoolers you are considering? This is a great idea.
