centri is more efficient..mmmmmmmmm:bs:
From Whipple's site (they make twin screws): "The Whipple twin screw compressor is 75% to 85% adiabatic and volumetric efficient while the roots is commonly 40% to 55%. Common centrifugal superchargers have a peak of 65% to 80% but do just that, peak. Over an entire rpm range, a screw compressor has an average efficiency far greater than the roots or centrifugal."
From Colorado Cobra's site: "The Roots blower has the lowest adiabatic efficiency of all the forced induction designs (including the turbocharger, which has to start off with hot exhaust gases to deal with) - generally around 50 percent. The roots type is so inefficient because it doesn't compress the air directly, but delivers uncompressed air which wells into the intake manifold, becoming more compressed, but with additional heat gain from the turbulence and reverse flows of air mixing. Centrifugal superchargers can vary from 60% up to perhaps approaching 80% efficiency, as can turbochargers; both are more efficient at higher rpm, which is another way of calling them more inefficient at lower rpm. The twin screw supercharger normally delivers lower output temperatures, for adiabatic efficiencies of 70-80% across the whole rpm range."
The KBs - boost-for-boost produce LESS heat than a centrifugal. That is with both blowers at 10#, the KB would produce cooler air. The KB DOES heat the air longer,because the blower is delivering full boost for the entire 1/4 mile run - and the centrifugal will only be at full boost a part of the time. Plus the blower case gets more heat soak from the engine because it sits on top of it.
The 2200 can support over 700 RWHP - so it won't run out of breath for most people...
