After months of fighting demons; my car is finally at the tuners. It's always fun to share a build and see what numbers folks guess for HP and Tq.
Build:
347
3.4" stroke
4.03" bore
.041" Quench
10:1 CR
91 pump gas
56cc AFR 185 Renegades with upgraded spring package
1.6 RR's
Systemax ll (Upper port matched to lower, intake ports cleaned up and matched to AFR's, upper opened to 75mm.) Work completed by FTI.
75mm TB
Lightning 90mm MAF with 4" piping
Mac 1-3/4" shorties into H pipe and out 2.5" duals. Straight through mufflers.
Ford LU34A injectors
Custom Comp cam:
.577 .574 lift
280/290 advertised
230/238 @ .050
7 BTDC 43 ABDC
55 BBDC 3 ATDC
112 Lobe seperation
108 Intake centerline
T5 tranny
25.6" tires
4.10 gears
Build:
347
3.4" stroke
4.03" bore
.041" Quench
10:1 CR
91 pump gas
1.6 RR's
75mm TB
Custom Comp cam:
.577 .574 lift
280/290 advertised
230/238 @ .050
7 BTDC 43 ABDC
55 BBDC 3 ATDC
112 Lobe seperation
T5 tranny
25.6" tires
4.10 gears
