I have been running this setup for a couple years now (Only 1000 miles or so) and I think the pump has recently been giving me problems. It is a Granatelli fuel pickup routed via -8AN line to the rear frame rail through a 100micron Earls filter, directle into the Aeromotive 11106 pump, routed through an Earls 10micron filter and then to the fuel rail. The setup ran fine for a couple years. Now after driving for more than about 20 mins or so, I can hear the pump start howling and watch the fuel pressure drop. Car runs like crap for about 15-20 seconds then dies. I have to let it sit for about 20 mins before she will start sucking fuel again.
Things I've tried:
Cleaning filters (even gutted 100 micron screen)
removing gas cap
Opening supply line to fuel rail to get pump to breath
Dropped tank to ensure no pinched lines.
Swapped for Brand new pump.
I called Aeromotive, they said the problem was the Earl's brand filters. They suggested I try their filters before sending off pump. Not sure if it's legit idea, or are they just trying to sell there product? Their 2 filters are $100 each! I don't have $200 to throw around at fuel filters just to troubleshoot.
While troubleshooting, I pinched off the return line. The engine displayed similiar symptoms as when I'm driving down the road. She finally died. She wouldn't re-prime until I cracked the return line at the fuel rail. Seeing how I converted from carb, I ran all this fuel line myself. It passes right by the exhaust header, and I am wondering if it is heating up and "vapor locking?"
Things I've tried:
removing gas cap
