what block is this??
25K views 15 replies 8 participants last post by  Kato Engineering
#1 · (Edited)
I picked up a 351W today and I cant find anywhere what this block is. Its a non-roller motor and the only thing it says in the lifter galley is 351 WCP 19 Anyone??
#6 · (Edited)
all those tell you is it is
351W made at the windsor casting plant.
the cast numbers will be on the bottom of the block.
i guess it is possible for a service replacement engine not to have a date code/cast number.
#9 ·
"too much spray"
has had too much craCK...
.......IF he is a "ford parts guy by trade"
then he is NOT much of a ford guy...
or is he even a GUY.........!!!>?????
#11 ·
the "351 wcp" markings are only on the thin -crap blocks fromafter 1980's
#14 ·
2MUCHSPRAY said:
Well A$$HOLE the person I got this motor off of hit the motor with a grinder and smothed out the block.
And thanks to everyone else for your help.
awwww dont take it so personal. its just the internet.
:worthless
the :bs: stops here :pain:
#15 ·
if there is no casting number in the normal place,
then all that can be said is,
why would you want a weak-suck-thin block...?????
the EARLY THICK BLOCKS did NOT have the ......."WCP"......designation or casting marks.......
.......if you were a REAL "ford parts guy",
you would know this.........!!!!!!!!
#16 ·
WCP
is also know as,
Worthless Crap Pile
Warped Cambore Parts
Wanna Cram-it Part
or any combination of the above.
it is a standard regular block.
nothing special....!!!!
