21 - 40 of 184 Posts
The only negative thing I’ve heard is that it may not be the best for like auto cross. Something about the rapid change in direction. However the individual who made the video that stated that said t would be perfectly fine for a daily driver/street car. Also in videos they seem super loud since there is usually no variable voltage to control pressure like the newer cars.
Discussion starter · #23 ·
I can verify that turning force does increase if you're rapidly changing directions. This car isn't an autocross or drift car, so it's not an issue for me. In the video I have, the pump does seem loud, standing next to the car, it really isn't loud at all. With the engine running it's inaudible.
An excellent write-up, and I'll likely be doing something similar with an upcoming Coyote swap, but I'm fairly certain one detail is wrong:
03-08 Volvo S60 electric power steering pump. These can fairly easily be found at local pick and pull salvage yards or purchased online.
Those S60s have a conventional belt-driven PS pump. Just this weekend I removed a PS reservoir from 2 different mid-'00s S60s in the u-pull-it yard, and the pump is mounted on the engine on those. That is confirmed by good ol' Rock Auto's parts database.
According to Rock Auto,the vehicles you want are:
'06-08 C70
'05-09 S40
'05-09 V50
Discussion starter · #25 ·
'06-08 C70
'05-09 S40
'05-09 V50
Yup, good catch. I think my fat fingers are to blame. I'll have to go change it in all the places I posted. Thanks.
I bought an '05 S40 pump this past weekend at the JY, it's the one with a remote reservoir so I have hide the pump completely in the fender. As a side note, I ordered the 14mm pump outlet fitting specified in the original post and it IS NOT the correct one for that style pump. It's too small, so I'm assuming the port on mine is 16mm. I'm gonna have to take it up to the parts house and figure it out.
Discussion starter · #27 ·
Yeah, after taking a look at a few of these pumps, some are 14mm, and others are 16mm. I don't know what dictates what size fitting it has.
Sorry about that. I didn't know at the time I made the post, so I'll update it. Hope you get it up and running and enjoy.
Thank you for posting on what fitting that goes in the pressure out on the pump, Ive been searching all over to do a -6an out of there, ordering that earls fitting now.
edit1.
Im going to mount the pump in the trunk use SS braided PTFE lines, al -6an, with a cooler and ive been thinking about adding an inline filter as well.
A number of guys who do HPDE or autocross on the FB groups have stated they have begun to move away from the volvo electric pumps. In this application the pump is operating in failsafe mode, and the main complaint is that it cannot keep up during quick steering movements.
I looked into it for a while and did buy a pump, however in the end it seemed like a novelty, or more suited for street cars. I know the Coyote swap guys are crazy over it, but if you plan on performance driving you may was to do your due diligence and maybe consider other options.
Im in the middle of coyote swapping, and im also going to use the volvo pump, fingers crossed for track abuse.
Discussion starter · #31 ·
The pump in failsafe mode runs at about 70%. If/when the CAN BUS code is broken we will be able to adjust the duty cycle making HPDE and auto-x shortfalls a thing of the past.
Ive been told just hook up a potentiometer and you can manual tune the voltage and adjust power assist that way.
Not quite so simple. It's CANbus controlled, so you would need to use a microcontroller to send a signal to the unit. You could use a Arduino or such. The issue is cracking the canbus "code" which would be easy if someone who was motivated had a working Volvo that one of these pumps was used on to filter out the code a bit. You could easily wire up a VSS variable reluctor signal to the Arduino and have it output the desired signal to the pump based on input from the VSS.
The issue is deciphering and writing the code. There have been folks working on it, but unsure if they ever figured it out.
  • Like
Reactions: TaraFirma
Hello,
I have this pump (4N513K514) and I'm looking at installing it in my 1969 Mercury Cougar to free up a belt.
I (Mistakenly) bought the pump without the wire harness and the harness I got on ebay had 2 cables, a larger gauge 2 wire one and a small gauge 3 wire one.
The issue I have is the color of the wires does not help me much in determining the correct way to wire it up.
The larger gauge wires are red and white ( I would have assumed it would have had a red (+12) and Black (Ground) wire) and the small gauge wires have the two end colors the same and the middle wire black.
Could someone please indicate, by position, the correct wires to hook up?
Also, the pump I have has a small toggle switch next to the large gauge plug. Does anyone know what that is for?
Thx,
Jay
Discussion starter · #35 ·
Hello,
Thx,
Jay
Can you post up a pick of the pump and the wiring harneses plugged it. That would help out a lot.
Using the picture below I've labeled the connections P1 - P5. P1-P3 are the 3 signal wires and P4 and P5 are the 2 power connections.
The switches is right below the power connector. If you could just indicate the usage of "P1-P5" that would be great, Thx.
Discussion starter · #38 ·
P5 is constant power. Use an appropriate gauge wire and a 40 AMP fuse.
P4 is constant ground. Attach this to a good chassis ground.
P1 is the remote wire that will turn on the pump. NOTE; the pump will start up and run up to 100% then slow down to the default 70% without a CAN BUS signal. I used a 12 volt source that is hot only while ingnition is in the ON position so I can use my acc power, and so that the pump is not running and drawing power while I'm cranking the engine.
Discussion starter · #40 ·
Just caught this in a google search but couldn't you just break the controller on the pump apart and hit the pump motor with constant batt power to see if it gives you full steering assist?
I have a couple of extra pumps at my house, and I'll see about doing this next chance I get. Best case would be to find something to communicate with it via CAN BUS so the amount of assist can be regulated.
