I have a few question about tuning my AFPR. I have a 306 '93 coupe with afr heads, trick flow intake, tfs 1 cam, and full bolt ons and i had a fuel problem i was running way too rich cause i had 24# injectors on a stock uncalibrated MAF so i switched to the C&l calibrated MAF and it cleared it up for the most part but im still not running as lean as i would like im on the richer side so i bought a kirbin AFPR and a fuel pressure gauge non liquid fuild and borrowed a wide band from a friend so i got all geared up to do it today and my fuel pressure gauge only goes to 15psi. now ive been told that my fuel pressure should be at around 43-45 psi with my mods and to fine tune it with the wide band so my first Q: Is this correct? and my second Q: How do i know im at 43 psi if my gauge only goes to 15? and lastly whats the generic AFR ratio to start on for my setup?
Thanks to all that help in advance
