I can get my hands on a '94 dohc 4.6 out of a mark 8 for $200. It comes with all the engine accessories, tranny, engine wiring, fuse box, and computer. From searching around on the net I believe that it has a AODE tranny, I think they switched to the 4r70w in '95. Will this block have the usual 5.0 style bell housing bolt pattern? I would like to use my T-5, I don't even know if the auto trany works.
For K-members. I have read that you can swap in a a stock K-member from a modular car and it will work. Why would I buy a 4.6 to fox body swap K-member, when I would just buy the 96 and newer k-member? What is difference in the modular and not modular k-members?
I came accost a few mentions here of cutting down a stock TFI distributor, adding a 18mm socket so that the distributor runs off of the exhaust cam, then using a stock 5.0 computer and wiring harness to run the 4.6.
Anybody have some dohc in a fox pics? Thanks
Jess
Jess
