My TFI has started the intermittent "surprise - not going to run the car for a few seconds" on me. Decided I'd go to the trouble to remote mount it to remove it from the heat/vibration which ultimately kills them. Thought ya'll might find the process helpful complete with pics.
Found the heat sink on a 94 V6 Cougar at the pick and pull : You have to remove a few fins for the Stang TFI module to be wired up - you'll see why in a second.
Cleaned up the heat sink and bought a new TFI for the car - mounted it to the sink using the proper heat transfer paste that comes with the new module. You can see it here with a piece of the wiring harness I'm building: http://forums.corral.net/photopost/showphoto.php?photo=61147&ppuser=30684 You can see the female connector attaching to the TFI, as well as the shielded wire that will run to the distributor - you can see the male connector that will plug into the distributor. You can also see the bare pigtail that forms part of the shielded wire -- the pigtail will go to ground. It will take three of these to run all 3 connections to the dizzy.
Here's a few shots of the shielded wire being constructed. Start with your wire (14 ga) run from the TFI to the dizzy. Wrap the outside of the insulated wire with a bare wire leaving a pigtail of the bare wire hanging out so you can ground it. Then wrap the whole thing with aluminum foil; then cover all of it with shrink wrap. Now the whole wire is surrounded by a metallic grounded shield so it can't pick up any stray signal that might throw the ignition off kilter.
http://forums.corral.net/photopost/showphoto.php?photo=61144&ppuser=30684
http://forums.corral.net/photopost/showphoto.php?photo=61145&ppuser=30684
http://forums.corral.net/photopost/showphoto.php?photo=61146&ppuser=30684
Here's the sink with TFI mounted, and all three wires hooked up to it. Eventually, all three wires will be shielded all the way to the dizzy, and bound together in factory style black plastic loom.
http://forums.corral.net/photopost/showphoto.php?photo=61148&ppuser=30684
I'll mount the sink/TFI on the fenderwell inside the 'cold air box' where my air filter resides -- coolest spot under the hood, and out of the way of water. Of course, I'll also have to relocate/extend the factory harness/plug so it can reach to the new TFI location and plug-in.
I'll keep posting pics as I make progress.
