T45 work with a 351W?
13K views 16 replies 8 participants last post by  SVTCobraLTD
#1 ·
I have a friend that is going to drop a 351 into my old 84 GT and can get a T45 real cheap. I was under the impression that it wouldn't work because of a longer input shaft on the T45. Am I correct on this one?
#2 ·
It won't even bolt up.
#3 ·
Moving to the correct forum.
Please keep the engine tech forum limited to ENGINE related topics. Thanks.
#6 ·
That's what I was telling him, but he had another guy tell him that it would work if he got the right bellhousing and that the T45 is stronger than a T5. He's eventually going to go with a stronger tranny, but he just wants one that will at least get the car going so he can drive it around and play with it a little at the track.
#8 ·
1. The front of the T-45 case is the bell housing.
2. There's a fellow in Texas who modifies T-45s to fit 5.0s, 351Ws, 351Cs, etc. It's a fairly difficult and expensive job. So unless the T-45 is in excellent condition and very inexpensive, you'll probably be better off to bypass it.
3. BUT, if you do want to pursue using the T-45, let me know and I'll try to find his web site or literature for you.
#9 ·
Thanks for the info, but I think I'm going to try to talk him into rebuilding the T5 I gave him with the car with a G Force kit. What do you guys think about that idea?
#10 ·
Much better idea than the T45.
Using the T45 on a 351 would be like getting your big brother to fight Mike Tyson instead of you taking him on yourself. He may last a little longer, but in the end, you'll both fail.
#14 · (Edited)
Take it to the track!
The thing here, though, is you know its going to fail. We know its going to fail. Its just a matter of time.
Even a Tremec 3550 probably won't hold up to a 393. Sure, it IS stronger, but its torque ratings probably aren't high enough for the 393. It will fail as well. Its just a question of when.
If you threw a TKO behind the 393, it would probably survive indefinitely. If you threw a T56 behind the 393, it would probably survive indefinitely. Its all a matter of what is designed to hold what amount of torque. If you're above its torque specs, you may be able to survive for a while, but it will fail and possibly leave you stranded.
#15 ·
Yes that is true but there are T5's out there with people running 10's on them and they are surviving but then there are stock cars blowing their T5's... i believe its due to adjusting and fluids. If its well maintained it will hold up, maybe not forever but a lot longer. As for the 3550... i was going to go with that because of less parts to swap. But i dont want to spend 1200 on one that is going to break after awhile. I want to be able to rely on it. Ill have to look into it more. Im trying to get over 550rwtq. For some reason that is my goal.
SVT
#16 ·
I understand your desire for an easy swap. For any N/A 302, Tremec 3550 would be the perfect solution. But you're running a stroked 351, that's a LOT of power.
Do a search, I know that the torque specs for all Mustang trannies has been explained before.
