Summit Brand Distributors are JUNK!
20K views 15 replies 13 participants last post by  Beasty306GT
#1 ·
I bought a Summit brand distributor and put about 3k miles on it in the last year. Recently, the car started having a problem where it would die after driving for 20 minutes. It would then fire up and be fine all day just after cyling the key off and then restarting. At the time it died, the tach and my datalog would read 0rpm even with the clutch out and the motor was still turning over. So, I would say it has to be either the pickup in the distributor or the TFI module which came on the distributor. Before I finished troubleshooting this, I changed the oil and found part of a roll-pin on my drain plug. I pulled the distributor and found that the roll-pin came from the distributor gear. I removed the roll-pin to swap it out, and the gear isn't even pressed on like it is supposed to be. It spins freely which is probably why the rollpin was sheared off on one side and it would have been completely sheared off by the end of the races on Wednesday if I didn't check this! What a POS! It doesn't feel like it is spinning as freely now as it should either.
Does anyone still sell a new OEM Ford distributor?
#3 ·
#4 ·
Dean,
Keep an eye on it! Mine only had 3k on it but they were a lot of race miles. I only go to 6k so it is nothing extreme. If I were you, I would pull it out now and make sure that the rollpin for the gear is intact and that it still spins freely. I would then repeat this check at every oil change.
I hope it holds up for you.
Does anyone know who actually makes the Summit brand distributor? The Summit guy said that they had a bunch of Mallory's get returned to them so he suggested an MSD. I have read a lot about bad MSD's so I sticking with the stocker but I want a new one.
Beasty, thanks for the link. I think my buddy might have one that didn't work out for him with his standalone computer so I might get it from him. If not, I'll be ordering the one in the link.
Craig
#5 ·
Craig,
Contact Barrie, he has a brand new Ford OEM distributor. Sorry to hear that! Good thing the motor is still ok!
#8 ·
Hey Tony,
Yes, Rich is the one that has it. Barrie has been in contact with him for me and I am going to get it from him tomorrow. Not sure if it is a rebuild or not but it says Ford on it and he thinks it was over $200 so it must be new. I think he got it from Smothers though and I didn't think they would sell an OEM one.
See you at the track on Wednesday!
