Long story short, built engine over the past few years while restoring the car. It's got new parts from head to toe. Car idles fine within operating temp just below 180 degrees. Car has a high flow water pump, a new thermostat, 3 core aluminum radiator with dual electric fans, and I run 50/50 mix with water wetter.
What happens is when I stomp on the gas or cruise at 2500rpm and up the car begins to creep to overheating (220+) within 15mins of initial start-up. Anyone have any suggestions on this?
What I've done thus far to troubleshoot.
Burp cooling system (cap off, bring to operating temp)
Verify water pump operation (radiator level drops slightly when pump circulates).
Replace radiator cap.
Replace thermostat with another 180.
Replace serpentine belt (thought possible slippage)
Verify Fans trigger at 180 and stay on (fans are pull setup)
Verify water pump is a counterclockwise pump.
Verified temp via alternate source other than stock gauge.
Pulled some timing from sealevel spark tables.
Verified afr (range at higher loads and rpms 12:1 ratio).
Pulled plugs to inspect, notice some glazing but already running coldest plug recommended. And possible due to earlier pinging before timing retarded.
Block was a new ford build.
No bubbles seen in radiator with cap off.
Kind of running out of ideas here and dreading the answer of a blown head gasket as a mechanical issue but also feel something just isnt right with the tune of the car since I never really had it going full bore yet and only overheats when at higher loads and rpms not at idle.
Running about 7lbs of boost at WOT on 93 octane on meth but also have a moderately high compression of 10:5.1
