Flywheel HP doesn't mean crap. Don't get caught up on it. As far as that is concerned, rwhp doesn't mean crap either, except as a bragging number. Chassis prep is where the real stars begin to shine, and chassis efficiency will more than make up for a pretty considerable HP difference.... for example, it's not uncommon to see a well-chassied car get outrun by 4-5mph or more yet out-ET a car of the same weight with no chassis work- there are plenty of guys on here that turn 109-112 or so that can't get out of the low 13s, yet there are guys on here that are in the low 101-105 that can get into the higher 12s. Get your chassis working first and then start to worry about HP, and with each increase in power make sure the car can still use all the newfound power to actually accelerate quicker instead of just creating a higher trap speed. Last time I checked, ET won heads up races, not MPH... Sorry if I was too far off topic to help. As a reference, 5.0/SF dynoed Robin Lawrence's Factory Stock motor at 380fwhp, and in the car with a T5, the car put down 330rwhp. That works out to 13.2% at the 380fwhp range with extremely light rotating mass. 15% should be close enough if you're really worried about it.
