From '92 PCED...
« TA -- Neutral Drive Input»
TA1 CODE 67/522, 525 or 528 SYSTEM IDENTIFICATION
A Code 67/522, 525, or 528 resulted from the voltage being high at either:
-- Pin 10 = A/C input
-- Pin 30 = Neutral drive
while cranking the engine or during KOEO test.
Possible causes:
-- A/C circuit shorted to power
-- Clutch engage/interlock circuits open
-- Neutral drive/gear switch open
-- Damaged processor
-- Starter relay disconnected during Self-Test.
For Manual Transmissions:
3.0L SHO and 4.9L
GO to «TA7».
1.9L MA SEFI, 2.3L, 2.9L, 3.0L, 3.8L SEFI Super Charged, 4.0L and 5.0L SEFI Mass Air
GO to «TA2».
For Automatic Transmissions:
1.9L MA SEFI, 3.0L Probe
GO to «TA10».
For all other engines:
GO to «TA8».
TA8 CHECK NEUTRAL DRIVE INPUT
l Key off.
l Verify A/C is OFF, if so equipped.
l Verify transmission is in NEUTRAL or PARK.
l Disconnect processor 60 pin connector. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
l Install breakout box, leave processor connected.
l Key on, engine off.
l Measure voltage between Test Pin 30 at the breakout box and chassis ground.
l Is voltage less than 1.0 volt?
Yes
For vehicles with A/C:
GO to Pinpoint Test Step «KM40».
For all others:
REPLACE processor.
No
Go to «TA9».
« KM -- WOT A/C Cutout (WAC) A/C Demand»
KM40 CHECK A/C INPUT
Service Code 79/539 indicates that the ACC/S input to the processor was high during Self-Test.
Service Code 67 indicates that during Self-Test, voltage was high on NDS (Pin 30) or ACCS (Pin 10) circuit.
NOTE:
Before entering this test, verify A/C selector is off (and shift selector is in PARK for AXODE and E40D vehicles). If A/C was on, rerun «Quick Test». If code 67 or 79/539 is present, continue with this test.
l Install breakout box, leave processor disconnected.
l Measure voltage between Test Pin 10 at the breakout box and chassis ground.
l Is voltage greater than 1.0 volt?
Yes
SERVICE short to power in A/C circuit. REMOVE breakout box. RECONNECT all components. RERUN «Quick Test».
No
For trucks with two digit codes and E40D transmission:
GO to «KM41».
For all others:
REPLACE processor. REMOVE breakout box. RECONNECT all components. RERUN «Quick Test».
TA9 CHECK NEUTRAL DRIVE SWITCH
l Key off.
l Breakout box installed, processor disconnected.
l Locate the Neutral Drive Switch.
l Disconnect vehicle harness from the Neutral Drive Switch and measure resistance across the switch.
l Is resistance less than 5.0 ohms?
Yes
SERVICE open in vehicle harness Neutral Drive circuit. REMOVE breakout box. RECONNECT all components. RERUN «Quick Test».
No
REPLACE Neutral Drive Switch. REMOVE breakout box. RECONNECT all components. RERUN «Quick Test».
