Mushy/spongy brake pedal after sn95 upgrade
8.9K views 31 replies 10 participants last post by  gordonsta
#1 ·
I have don't alot of searching and from what I see I might need to work more on bleeding them.
I installed 99 pbrs in front, 95 v6 rear calipers, 95 v6 mc
This is in a 93 4cyl car the brake lines are all stock except where I adapted to the new calipers. I also left the booster stock as it looked no fun to change. I am running a mild crammed 351w so this could be an issue I suppose
I have tried to manually bleed the brakes several times and didn't see any air bubbles and also haven't found any leaks.
The brakes are firm when the car is off but the moment I start it up the pedal goes very mushy but does still stop. I just don't think I'm comfortable with how they are. I did adjust out the booster stopper but that didn't help. Any advice is appreciated
#2 ·
Are you 100% sure you mounted the front calipers on the correct sides of the car, so that the bleeder is up high? They'll mount both ways, but if you get it wrong, they won't bleed.
#4 ·
What MFE said.
I had SN95 stuff with stock MC/booster, and my pedal was pretty stiff and felt really good.
How did you bleed them? With someone else pumping the brakes up (this way works good as long as you have someone in the car that's really standing on the pedal as hard as they can. Your GF prob. won't cut it) does a good job, but takes some time. Using an air compressor is an awesome, easy and quick way you can do it yourself without the need of an assistant.
#6 ·
Didnt want to start a new thead so ill ask my question here. I did a SN95 brake swap on my car with a 93 cobra MC and the plug for the PV and a adjustable valve for the back brakes and i still have a soft pedal. All i can think is i didnt bench bleed the MC. Could this be my problem? I do have the calipers mount correctly with the bleeder up. I bled all the brakes and have now leaks. Any input would be great???? Thanks
#7 ·
Also i do get a stiffer pedal with the booster unhooked when the car is not running????? also used a harbor freight air compressor bleeder kit to bleed brakes. I am stumped
#9 ·
i dont have the cables installed or have them at all. This can be a problem?
#10 ·
Didn't bleed the master cylinder may do that after the later suggestion as I didn't hook up the ebrakes yet. Do I simply pull the lever where the cables would hook to rear caliper. This would make since to me and I didn't think about that. I did bleed with someone else also so I may try the compressor bleeder if these don't work.
#11 ·
After bleeding the m/c I like to reverse bleed at the calipers to push all air in the calipers/lines to the m/c and then vacuum bleed to pull any residual air out of the calipers. The recommended sequence I have read is passenger rear, driver rear, passenger front, driver front. I don't know how much it matters but that's what I follow. The bleeder below has worked very well for me.
V5 DIY Reverse Brake Bleeder - Phoenix Systems
#12 ·
It matters simply because you start with the caliper furthest away, and work your way to the closest. So the process generally is always the same.
Bench bleeding the MC is def. better, but not necessary. Just takes longer to bleed the brakes once everything is installed, that's all.
#15 ·
I understand the logic, but what I said was I'm not sure how much it matters (on the fox mustang). The two rear calipers being essentially equidistant from the m/c for instance, and on a non 3-2 converted m/c the fronts are completely separate from caliper to m/c anyway. Regardless, I follow the order because you might as well have some sort of order to follow. ;)
#17 ·
I'm guessing you're looking for those plastic inserts to bench bleed your MC?
Did your MC not come with them? I bought mine from MM, and mine didn't come with them, I had to borrow a kit a buddy of mine had. I looked around briefly, and couldn't find anyplace that had them.
You know, I'm sort of in a similar boat as you. Maybe. What I have at the moment, is 13" Cobra's up front, stock SN95 rears, 94/95 Cobra MC, stock BB. I was fine with the stock BB with the standard single piston calipers up front, but now with dual, I have to press the pedal much harder (i.e. not as much assist as what I had before) and I'm wondering if maybe that's what you're running into, as your PBR's are dual piston as well, correct?
I know for me, it seems as the only way I'll now get my pedal back the way it was is to install the 93 Cobra BB. You might just end up having to do the same. Or, you could use the 94/95 which are physically the same size, but the stud placement is slightly different.
#23 ·
Wouldn't that be closed all the way?????
Mine needs to be turned in(cw)for MORE rear brake,out(ccw) for LESS.
#27 ·
Tried that and still no luck. I used the bleeder on all the connection including the lines on the banjo bolts and all bleed fine with no bubbles. I did take the bleeder valve off and that showed no bubbles but with it connected there are millions of tiny little bubbles. Am I over looking something? The pedal is horrible and the car doesn't like to stop
#28 ·
Did you gut the proportioning valve, and if so, did you install the solid FRPP plug in it?
