Mini-Starter Wiring
13K views 12 replies 5 participants last post by  ross2004
#1 ·
So first background on the car: 1987 BMW 3-series with a 347 SBF, trunk mounted battery, "old style" starter. I experience a good deal of heat soak in the starter after running on track, so I'm replacing it with a mini-starter to hopefully fix that problem and also save some weight. Traditionally the mini-starters are wired this way:
I would prefer not to have my 00 gauge battery cable from trunk to starter hot all the time. Judging by the 10-12 gauge wire that's recommended for the mini-starter's solenoid, I'm assuming it pulls some decent amps and is why it's not simply triggered off the ignition switch. So, what if I left my main battery cable as it is (keeping the long run cold when not cranking) and simply added a relay off the ignition switch with a fused 10ga wire? I'm I missing anything as to why this won't work? Here's a simplified drawing of what I'm thinking:
#3 ·
The mini starter has a solenoid inside that engages the starter gear. It functions differently than the big starter. If you wire as you plan, I believe you'll find that the mini starter will continue to turn after you release the key. Been through this on mine. Route and insulate the 12v cable carefully and fuse (MegaFuse - 300A) the battery ground. And you can lose the big/ugly fender mounted Ford relay and replace with a standard 30A automotive relay to trigger the starter internal solenoid. Mine's been safely working for 16 years....
#9 ·
Looking at your diagram, I agee it will work.
However, you have a **needless** relay that adds needless load to the start key terminal.
The ministarter already has a high current contactor inside. All you need do is run a heavy +12 to the battery lug of the mini, and then switch the small spade lug off and on with a start relay to start.
#10 ·
Here is a link to what I did. It goes through a few iterations as my system evolved from street performance to serious track performance.
Work your way down the page past things you do not care about:
Battery Wiring
