Has anyone used these with good luck any info would be appreciated thanks
Pushrod lengths appear to be identical on both intake and exhaust valves on my Canfields.How much different are the pushrod lengths required for the shaft rockers versus stud mounted rockers?
I could get to working on that soon after I get a few big things done. I was planning to start with fitting the lower intake and have Tom port it to match the heads, and then work on the valve covers(outlets, lettering, and paint).
So I did not build this engine, but obtained it through an insurance deal. It was setup with 6.800" pushrods and no-name rocker arms. The pushrods were all mismatched in terms of their manufacturer as well. Using the valve stem tip markings, I've determined that the 6.800" pushrod is correct even for the LGM shaft rocker system, but I've ordered a set of EnginePro 5116 series cromo pushrods for a matched (and much stronger) set.Very good, but did you ever mock it up with regular stud mounted rockers, the pushrod length?
