I had a set of GT40 iron heads and used a FelPro 1250 gasket. I did not use the exhaust crossover eliminaters, as I am carbed and needed the heat for cold weather warm up with the carb. But, upon removing the heads, I noticed that oil was creeping up the 2 bolts on either side of the exhaust crossover. I thought it was the valvecovers and not the intake gasket. I want to make sure it does not leak oil like this again with my new 347 combo.
I'm wondering if anybody else had this problem and if a little RTV or thread sealer on the 4 center intake bolts will stop the leaking...
