Jeff here are the actual instuctions on the recall
I couldn't get the pics to copy)
Mustang 3.8L and 5.0L HO
Record radio preset stations, then disconnect the battery negative cable.
CAUTION:
When securing the CBM to the fan shroud with the tie strap, be sure to wrap the tie strap around two (2) fan supports only and NOT a fan blade.
CAUTION:
The CBM for the 3.8L Mustang has one (1) circuit breaker, and the module for the 5.0L has two (2). Make sure the CBM you are installing is for the appropriate engine configuration. If the wrong part is installed on the vehicle, it will fail to protect the circuit.
Connect the CBM to the cooling fan motor, then connect the vehicle harness to the CBM. Secure the CBM to the cooling fan shroud with one (1) of the supplied tie straps. See Figure 8.
FIGURE 8
Take up the slack in the cooling fan shroud wire harness on the right side of the coolant recovery reservoir by gently pulling the harness through the reservoir bracket. Then fold the wire harness over on itself and secure it with the other supplied tie strap as shown. See Figure 9.
FIGURE 9
If equipped, position the radiator upper sight shield onto the vehicle and install the fasteners.
Connect the battery negative cable and set radio stations.
Check cooling fan operation.
