Driveshaft spacers: Good or Bad?
1 reading
10K views 9 replies 6 participants last post by  XSPOWER
#1 ·
When putting a tremec or "Z" T-5 in our cars, you need to either put a driveshaft spacer or get a longer driveshaft. Are the spacers safe? It always seemed to me that if you put a spacer with longers bolts, when you dump the clutch or powershift, it would be putting a heck of a force on those bolts. Without a spacer, it pretty much has to shear the bolts off, but with a spacer the head of the bolt moves away from the rearend and you now have the spacer that can twist a hair which seems like even though it is tight, it could twist like heck on those bolts. Am I off base here in my thinking or is it better to cough up the 4 bills for a new shaft?
#2 ·
i have no problems dumping the clutch with my 500 hp and slicks with one of those spacers in there... when you put a spacer in there you use your 4 old driveshaft bolts and bolt it to the pinion yoke and then attach the driveshaft to the yoke with the longer bolts that come with the spacer.
#4 ·
Just went on to steeda, 50 bucks!! for a damn chunk of aluminum!! I can have my drive shaft resized for that price or a little more! Is there any other companies selling these spacers? I noticed it's not very think either, will it work for a tremec? I'm not trying to steal your thread XSPower, I'm just curiuos too!
#5 ·
I didn't know the spacer bolted to the pinion flange. I just assumed that longer bolts went thru the driveshaft, thru the spacer and then to the flange. With the spacer bolted to the flange I would have no fear of it. Makes good use of the extra holes in the flange. What brand spacer did you use?
#6 ·
oh man.. its been so long i dont remember where i got it. i do know mine is steel though and most places now make it in aluminum.. i think im gonna take mine out and copy it in aluminum on my dads lathe cause the steel one is friggin heavy!! lol.. and miley it works for a tremec. that is what i run.. the spacer only gives you another 5/8"
#7 ·
Steeda was the only outfit I found that makes em.
Their unit just uses the 4 longer bolts, and you discard the old ones.
We've pulled high 1.6 with it so far, but no real good digs yet.
My take: The bolts can only move to the side if there's clearance in the bolt hole. If all 4 bolts are tight, there's no room for them to go anywhere.
#8 ·
how do u know if u need a spacer? if i were to unbolt my driveshaft i could push it into the tranny some more, so naturally to get the driveshaft to bolt to the pinion flange i need to pull it out some. is this situation candidate for a spacer?
#9 ·
I installed a 3550 in my 94 and used a 1/2" aluminum spacer I made at work. From my understanding the 3550 has the same length input shaft as 86-93
T-5's. 94-95 cars, the input shaft was 17mm or 5/8" longer. I had to use a bellhousing from 86-93 car and a spacer on my aluminum driveshaft to make up for the 5/8" difference. My spacer is only 1/2" thick but I've had no issues in over 2 years of service. Also, for what its worth, I just used the longer driveshaft bolts.
#10 ·
It is normal to be able to slide the shaft in and out of the trans when installing it. As your car goes down the road and the rear end goes up & down the shaft will move in and out of the trans a little, so there has to be some slack. The spacer is only needed if you do a tranny swap like to put a tremec or "Z" t-5 trans in a 94-95. Most trannys are the same length but the 94-95 bellhousing is 5/8" longer than the fox cars. The input shaft on the front of the trans is also 5/8 longer. So if you go to a Fox style bell & trans or tremec set-up the trans etc. all move ahead 5/8" thus the need to put a spacer on the driveshaft.
