I’ve got a 393w Twin Turbo setup and am considering a switch to a 55GPM electric pump or swapping the current 5.5” March Pulley to a 1993 Cobra WP Pulley, the current pump is a Weiand Mechanical Pump.
The turbos make things extremely hot and I’ve done quite a bit to address the heat issues, next on my list is to get the engine temps under control at idle and in heavy traffic, mind you this car isn’t driven much. Currently with the 195* thermostat the Taurus fan comes on at 205* and shuts off at 200*, from time to time I’ll see as high as 210-213* in heavy traffic scenarios. The cheapest option is to overdrive the current pump and see the results, I’d like to avoid the fan being on all of the time and would love to see it staying around 200* but Iblile the idea of the electric pump running all those gallons while at low idle and I can see it’s benefits at the track, just wanted some more input from people who’ve done both hopefully.
