Hello everyone, After a year of trying to diagnose my airbag problem I might have narrowed it down. I have read every thread available on airbag help and practically know the entire “Very Useful” website verbatim. I have replaced every sensor with used (in working condition) sensors and also have a NOS module that I am using in addition to another module that was reset by the airbag guys in Texas. They were both flashing code 8 so I replaced the front sensors. Now I’m getting a code 4 so I replaced the sensor behind the driver’s seat mounted to the b-pillar area. I have a 91 GT convertible. I have done all the different steps in the very useful website and I think this is my problem:
Low voltage at pins 11 and 12 can be caused by:
Does anyone have any advice on how to fix this? Should I just splice in new wires to bypass the ones at pin 11 and 12? I would rather not cut into the harness but if that’s what it takes then I will. As always, thanks in advance for your help.
- Resistance to ground on circuit 614 or 623. Circuits 614 and 623 should be open circuits to ground when the diagnostic monitor is disconnected from the harness. Resistance to ground on these circuits can cause a drop in the diagnostic voltage on both circuits.
- Low resistance in one or more of the primary crash sensors. If the resistance of one or more of the primary crash sensors is lower than normal, the voltage on pin 11 will be pulled down too low,
- A poor ground on pin 3 of the diagnostic monitor may cause voltage to appear on the diagnostic monitor ground reference. Any voltage on the ground reference will cause the diagnostic monitor to measure the voltage at pin 11 as low, even though the voltage at pin 11 with respect to the sheet metal is normal.
- Intermittent battery voltage at pin 13 can cause the reference voltage inside the diagnostic monitor to fluctuate and cause Fault Code 4 in some circumstances.
