CalBoy makes a good point however, that’s assuming the cam gear was all the way counter clockwise when first tightened which probably wasn’t the case and I said there was not a lot of slop on the left gear. Since this car is a project mule, I decided to test the right cam off camera, knowing that gear had a bit more play. With the right gear tightened in both the full CW and in the full CCW position, I got a 108* and 111* reading. Given that results, I believe a 3 degree variance may not be uncommon.
