Ive got some in my engine bay that has discolored/lightened up.Ive also got some that has kept its color.I know it sounds like Im being awfully picky but does anyone know who has the good stuff? Its just annoying to have to redo it.btw,its blue.
What is expandable sleeving?Ive never heard of it.Is it like the split tubing?Thanks************^^^^^^^^^^^^^^^^^^***********
Hello Stok/
Just a Suggestion[If it can work].I've used this expandable sleeving on some of my underhood Wiring.
Next Round,I'm using as much as possible[Black,but they have various colors,I believe blue also].
I'm hoping I can disconnect the waterproof pack conn. and slide the sleeving over them.Once I cut the sleevingw/a Hot Knife[which are usually pretty cheap to cut the TechFlex] than I'll use Black & Red Heastshrink to dress up the ends of the Sleeving.I think it may come in heat resistance.
It can look real nice when done.It's alot of Time & Patience,if you want to go that route/.
The Split Loom I know comes in a Flame Retardant.It's usually striped w/a Gray Tracer.That can look great too,and give you protection also.
Just a suggestion.Good Luck whatever you do.
Regards/
Raymond
