Hi, so I just finished installing my Astro A5 trans just freshly put together and I am running into an issue. I noticed that in order to get it to shift into gear consistently I needed to tighten my clutch cable (turn firewall adjuster out from firewall) almost all the way. There are only a couple threads left on the interior side of the firewall where the adjuster comes through. I a using the Maximum Motorsports 3 piece set (billet quadrant, firewall adjuster and they supply the factory clutch cable). I have a stock bellhousing, stock replacement steel flywheel, Ram Powergrip clutch and the aforementioned astro a5 26 spline trans. I am able to drive the car and perform shifts but at times there is a little trouble getting into gear (especially 1st gear). As a test to make sure the clutch disk is released enough Tony at Astro told me to push the clutch in to the floor, count to 4 seconds then try to put it in reverse (it should go into reverse with no issue or grinding), the 4 seconds give the input shaft time to slow down.) My setup does not due this so I am convinced I am not getting enough release when the clutch pedal is dropped to the floor. Upon further examination when I had my wife push on the clutch pedal while I viewed the fork As soon as the pedal travels all the way down to the floor, the fork makes contact with the bellhousing which is probably not good. I am assuming that the release I need is somewhere even further than the point when the fork touches the bellhousing. When the clutch pedal is not being pressed the fork is just about in the middle of the opening in the bellhousing. I was told by Ram that I want the fork to be slightly angled to the rear of the car when the pedal is not being pressed. I probably have some wear on the ball stud and clutch fork (come to think of it the fork did seem to fit kind of loose on the stud.) I am not sure if a new ball stud and fork will be enough to give me the end result desired or do I need to space the clutch fork pivot ball closer to the pressure plate? Anyway I guess the trans has to come back out or will this condition improve as the clutch breaks in to where the fork is as far forward right now as it will ever go? If I do have to remove the trans again is there a way to check the fork throw before re installing the trans (I am thinking no because the input shaft needs to be in the clutch disk to test for throw? Just trying not to have to keep pulling the trans in and out. Is there anything with my current setup that I am overlooking that could be leading to this fork contacting the bell? I can actually drive the car like this but you can feel something isn't right with the shifting being that it is difficult to get into gear. Just don't want to mess up that very expensive (to me at least) astro A5 trans I just put in. Please help/ opinions/ suggestions, all wanted. Thank you
