I'm finally replacing the original injectors on my '93 5.0. I ordered these Bosch 19s https://www.rockauto.com/?carcode=1134076&parttype=6224 from rock auto because I think my stock ones are starting to stick. Car smells rich and check engine light is coming on. The car has cam, heads, intake and was tuned with a SCT chip. Pretty sure the stock 19s are maxed out but I didn't want to get retune for 24s. Car made 305hp to wheels.
So should these new 19lb injectors run about the same as properly working old 1993 19s?
