I just rebuilt the transmission and it dosen't like to go into drive or OD. 1st, 2nd, and reverse work perfect. I put a shift kit into it to give it a harder shift. I rebuilt it using the ATSG manual page by page. Used Alto trans. rebuild kit, and replaced all seals, O-rings, and bearings. Had the same back lash upon the completion, and don't know what went wrong. Took it to the dealership and had them do a diagnostic test and they said it wasn't an electrical problem. Not sure what the PSI readings for the shift points are, but plan on doing it sometime soon. The pump internal gears were fried, so I replaced the whole pump. The direct drive drum was almost welded together, so I got a new one too. That drum was a little bit different, but had to run 4 clutches insted of 5, and run 2 steels on top of each other. The transmission shop I was dealing with said that would be fine to do that. The measurement between the snap ring and top steel were still with in specs. I tested the transmission in the air before setting the car down. I ran it through the gears manually to make sure it shifted fine, than did it in drive to let it do it by itself. It shifted just fine while doing that too, but as soon as it was on the ground 3rd and OD quit. Any help would be greatly appreciated.
