I'm in the process of putting the SN95 Brake setup on my '91.................... I NEED THIS ADAPTER !!!
Where can I buy this adapter ?
I second that. That is how i did it, just one less connection you have to worry about leaking. That old fox fitting may need replacing by now anyways, we all know how soft they are and how tight they become after years of service. If you go this route just remember to use a Double Flare.mesostophiles said:Screw it cut off the fitting on the old fox line and get the 94 up fitting and reflare the line.
The cobra softline has a 3/16 female end. The fox hardline has a 1/4" male end. The adapter is weatherhead part #7828.Mavrick said:So the stock fox fitting is 7/16? And needs to be 1/4" to fit into the SN95 flex line?
Yes...it just got discussed quite a bit here.Mavrick said:so i only need 1 fitting, only on the passenger side to adapt the SN95 flex line to the fox hard line?
Sounds right to me.Blown331Coupe said:Are you referring to the fitting of a SN95 Cobra being different than a SN95 GT? When I upgraded my GT to Cobra brakes the Cobra brake lines bolted right up to the GT's hard lines.
I never asked anything about Cobra brakes or fittings...in my original post I was asking about the adapter for SN95 V6/GT FRONT soft lines to fox hardlinesCraigBlackCoupe said:The cobra and standard sn95 softlines have different size fittings? I was unaware that the v6/GT sn95's needed an adapter for cobra brakes. Reason why I ASSumed the cobras were the same as v6/GT's.
I'm still wondering what the hell is going on in this thread. Are you not getting it???302EFI said:I never asked anything about Cobra brakes or fittings...in my original post I was asking about the adapter for SN95 V6/GT FRONT soft lines to fox hardlines![]()
I'm still wondering where Cobra came up in all this???![]()
Of course the softlines are going to be different. Each model is using a different caliper. But they all have the same threads mating to the hardline, hence the need for an adapter. Glad we are clear now.302EFI said:I went to the part store and bought the new softlines, they were saying the softlines for the Cobra were different then the V6/GT.
Mavrick said:www.mustangparts.com sells them. I would like to know the thread sizes, as i could probably find the piece in town for a few dollars.
