Accufab TB Back-to-Back NA Dyno Results
I was doing some intake dyno testing and decided to compare the Accufab TB and the OEM TB in a same-day, same dyno comparison. The same day data is with a modified plenum cover. I've also included a same dyno, different day comparison between the Accufab TB with a stock cover and the modified cover.
For my specific combo, I saw no gains from the Accufab TB. In fact, if the delta HP between the two TB's is summed, the Accufab TB resulted in about 12HP less than the stocker across the HP range evaluated for the ported plenum (same-day, same-dyno data). Stock plenum data is noted as being 'different-day' relative to the ported plenum data, so these results are not as meaningful. Although. for most of the rpm range shown, the delta is only 2-3%, which is pretty much noise as far as different day dyno results are concerned.
Here's a link to the results.
http://www.flash.net/~ivc1/cobra/acutbcom.html
One interesting comment that I got from the dyno tech was that the Accufab TB had a lighter pedal effort. That's also an observation that I made when I first installed the Accufab TB. It's also an observation that I've read from other guys here on the Corral.
When testing some intake mods, I once forgot to install the external return spring (when using the stock TB). The result of the reduced pedal effort was the impression of increased throttle response/more power. I'm wondering if the reduced pedal effort/throttle sensitivity of the Accufab TB is leading to the 'feel' of more power and increased throttle response in NA application.
Anyone have any comments or experiences.
