87-93 clutch cable ?
1 reading
1.3K views 6 replies 5 participants last post by  Jeff Cardwell
#1 ·
What Ford OEM cable is everyone using in their Fox Bodies. I have a stock Fox Cable and it is too short to use with my UPR Quad and Firewall Adjuster. Thanks in advance for any and all input.
Thanks Again
Jeff
#3 ·
Make sure you hook it up top first then proceed to the bottom on clutch fork coming out of the tranny....
#6 ·
Just finished installing the FACTORY CLUTCH CABLE, FIORE ADJUSTER and kept my UPR QUAD on a Spec Stage III and have NEVER in 8 years of driving been so happy. I had an AOD swap straight into a Tremec w/a Ram clutch, so I never experienced a factory clutch, but let me tell you this feels better then any set up I've ever had in the car. BEST firewall adjuster is by far the FIORE, which I picked up from Atomic Performance (he is on the site). Now I know why they charge $130.00 for the FACTORY CLUTCH CABLE. IT'S WELL WORTH IT!!!!!!!!!!!!!
http://www.atomicperformance.com/index.asp?PageAction=VIEWPROD&ProdID=736&HS=1
