I am planning to build up my 4R70W trans with fall and need some info on the uniquenesses of the 4R75W vs a 4R70W from a 5.4L truck. I know the 5.4L 4R70W had better parts as listed in Jerry's article on TCCOA, but wondered if there are other parts in the new 4R75W that came out in 2004 for the 300HP 5.4L in the F150.
Would it be a better starting point to use a 4R75W than to use a 5.4L 4R70W?
This is going in my 4500lb AWD Ranger with a 351W boosted at 12-13psi Kenne Bell. Should be 500+ rwft-lbs. With the power and weight, this thing has to be strong!
Also, planning 10.5" PI converter.
