I want to build up a 408stroker but have a coupe of questions first.
1. For the 351W block, should I just buy a used block and get it worked on or should I buy a Dart 351W block? How can I go about strenthing the block inself?
2. What company should I get the stroker kit from? I want to keep the compression low as I want to put either a blower on after.
3. What cam should I run in this beast? Lift and duration?
4. Heads? Can I use normal 5.0L heads (aftermarket) on this engine or do I need something special, if so where do I get them?
Thanks in advance.
Thanks in advance.
