408 carb jetting???what you got??
7.3K views 7 replies 5 participants last post by  blackcobra46
#1 · (Edited)
i got a 408w was wondering what size carb you running and what jet size??thanks for your help....and also if you have power valve still in it??what brand too. o heres my combo...408 W,,victor jr heads .2.05/1.60,,cam motion cam soild roller nos grind 264/274 @.050 .701/.688 lift 112lc..1.72 rockers stud girrdle,,4340 eagle crank 4.00 stroke,,eagle h beam rods 6.250 long,,srp flat top pistons= 12.5 to 1 compression,,super victor intake ,,750 holley d/p ''for now'' msd 6a box and dist , and timing controller,headman race headers into 3in flows,,lt. weight ft. k member, ft coil overs,rear south side bars uper and lower,air bag in rt. side,,alum d/s/,,tko trans,center force dual fiction ,,pro 5.0 shifter ,with adjustable cable,,out back got 8.8 rear with 31 spline moser axels,,ford tract-lock diff,,8 pt roll bar,,hi toque starter,,00 battery cables,,optima red top batt.streetable stiil got a/c/,,p/s,,and ''some power brakes''havent run this motor yet!ran 10.59@130 with milder 351w 60 over with 175 shot..
#4 ·
holley 870 street avenger, 78 front...84 back...a/f at 12 .2 , a little rich, but safe
#5 ·
ok im the thread starter here so let me tell you what i got ,,750 holley #4779 got 4.5 p/v. 74/80 is that to lean...im fixing to run it and dont want to run lean i got a 150 shot on it right now....??what should i jet this carb to fellows...with out messing with the air bleeds...im going to get another bigger carb soon but just want to run about 4 times total..till i get diff carb,,,its hard to see if iam running lean with the race gas...plugs look leaded color????go back to top and see my combo..thanks for your replies...
#6 ·
you really don't need a bigger carb...just about everybody runs a 750..it figures out with the formula, so it'll handle the cfm's. whatever you do, don't mess with the air bleeds. you might go a little bigger on the jetting, but with mine, it's rich. black sooty crap all over, but i'dd rather be safe than sorry. my a/f on the dyno was mid 11's. good luck
