having done a number of these into a fox or a fairmont,
EACH and EVERY PERSON sees sifferent things that they like and dislike about each installation... there are many different ways that work.
the main thing is HOW you want the hood line to appear....
each installation differentces create their own different "other problem".. so, one may give you a better hood line, but creates difficult header install / clearances..
some other type will create oil pan problems.
oftentimes you have to have to buy the "drop mounts" and then also try the motorplate...
...or even then try a stock mount with shims to RAISE....
overall, still, a tubular K member will open up a number of clearance issues and be much easier to work on engine later.
