1995 econoline van - What's a good towing cam? 351w roller motor ?
1 reading
10K views 9 replies 9 participants last post by  edwardo
#1 ·
My friend has a 95 econoline van with a 351w. The van is set up to be a SPL van with a Wall and a ton of stereo equipment (i.e Heavy!). Anyways, he tore the engine apart for a rebuild and was going to put a "tow" style cam back in it when he puts it back together.
What would be a good cam to use? Would a stock cam with some 1.7 RR be better?
Thanks for your help,
Justin.
#7 ·
Use the stock cam and 1.7 rockers unless it's a mass air vehicle then get the XE264HR-12 and use stock or 1.6 roller rockers. Also adding longtube headers and a single 2.5" medrel bent exhaust system will help loads, if all you can get is compression bent pipe go with a 3" cat back.
