I'm sorry for such a vague post, I assume all battery relocations are relatively similar, I wanted to add an inline fuse to the main 2 gauge wire to the front of the car for two reasons, safety, and my current cable is a couple feet short. I have seen two different styles, the ones normally used in car audio systems, and the mega fuse style. I have a 175 amp mega fuse and holder I'd like to use for the install, but my question is, with a 12 volt charging system and 2Awg wire, what should I use and will it actually blow if anything goes on?
