World windsor junior heads
1 reading
8.8K views 8 replies 8 participants last post by  streetfalcon
#1 ·
Ive got a 306 with a tfs stage 1 cam.
I'm looking for a decent set of heads. I am seeing these cast windsor jr's for about $800 which is in my budget.
Are they any good? Does anybody have any experience with them? Et's or dyno #'s? Should I just hold out for aluminum heads?
#2 ·
I'm a windsor jr user here and enjoy them very much. They can be ported quite a bit too since there a thick casting :) See sig for dyno results.
#9 ·
wow, that combo is eerily similar to mine . . .
306, 10:1
home ported Windsor Jr alums
home ported Professional products ripoff air-gap
670 street avenger with the choke horn milled off
1 5/8 longtubes, 2.5" exhaust
t5
made 300rwhp and 312rwtq
Out of the box, all the world heads are terrible. The ridges above the seat, around the guides and in the port leave a lot to clean up. They can be made to work very well though.
I have seen a very worked set of iron windsor jrs run 6.20s on the gas in a light car.
But I would second looking for used ones . . . I bought mine off ebay for $800
#3 ·
If your thinking about going with those heads ,GO with the world sr's there
there alot better with the 202 intake valves
I ran the aluminum ones and dyno'ed on motor 306rwhp,and 538rwhp with 15lbs of vortech boost ,with a F-CAM....All said and done with the totaly stock bottom end with pushing 200k on my old 302 motor.YES THERE GREAT HEADS
RAN A2 EPPING NH. 10.9@128MPH THRU THE TRAPS........
I JUST SOLD MINES A COUPLE OF MONTHS AGO FOR $850 .
AS FAR AS $800 FOR THOSE JR'S (ARE THEY PORTED? )
IF THEY ARE GO FOR IT ,THEY'LL DO YOU GREAT FOR WHAT YOUR DOING ...
#5 · (Edited)
I've had them, and as far as I'm concerned, there are better heads on the market within your price range. They flow about what a GT40 head does unported, and by the time you put money in port work into them, you could have just bought a better head to begin with.
Ohh, and a fyi, I sold my jr's, freshened and with mild port work for $500.00, and I've seen a bunch go for about that, so $800 for used heads is kinda steep
http://forums.corral.net/forums/showthread.php?t=993187
#8 ·
I had the Jr's, GT-40 intake, E cam, long tubes, etc and ran a best ET of 11.98 @ 112. car had AC and PS at the time.
I used a dremel to cleas out all the casting flaws in the ports and to buff (not polish) the ports and chambers. Did the same to the intake lower.
I really liked mine... then I built a 408.
My recommendation would be for you to save some more money and put on the AFR 165's.....
