Which Way to Install Fel-Pro 1415 Header Gasket?
1 reading
18K views 16 replies 8 participants last post by  XSPOWER
#1 ·
One side has print and says Fel-Pro and 1415, and the other side is just blank. I thought the print side went toward the head.
#2 ·
It doesn't really matter, just soak them in water overnight before you put them on and they wont leak.
#3 ·
No ####?
Seriously?
#7 ·
Blank side on the heads, tighten them. Done.
#12 ·
They do not. One side has a design with light blue/dark blue print and it is stamped "Fel-Pro" and "1415". The other side is plain.
I've gathered from others that the flatter plain side goes towards the head and the design with print goes towards the header.
#17 ·
You wouldn't think that a material designed to withstand exhaust temps would soak water. I'll have to try it next time. Sounds like a good tip. MR Gasket makes a great graphite header gasket, but the port holes don't line up for crap (at least on my AFR's). I think they are called Ultra-Seal Graphite. If they would copy the 1415 shape, it'd be a awesome gasket
