I need help choosing what valve springs to go with. Im running a 351w with canfield heafs tfs stg 2 cam and novi 2000 blower. Problem is i cant go past 7psi and i think its because of valve float. Im running the valve springs that had came with the heads don't know the specs, should i go with tfs stg 2 springs or something stiffer ill be running around 14-17lbs of boost.
