What size plugs for the smog holes on some 85 302 heads???
5.6K views 8 replies 7 participants last post by  jwhite1993
#1 ·
What size plugs can I use for the smog holes on a set of 85 heads.I am getting rid of the smog.Need help putting motor in tommorrow eve
#8 ·
Ford makes a plug kit too... its like $9... the guys at the counter might take a while to find it, but its out there... just make them look.
I have used them several times when removing the smog equipment from 5.0s.
Good luck.
#9 ·
spark plugs worked for me. I had some carbon build up so I stripped the threads on the first spark plug, but they are only like $2. Just break off the end, you can't see it anyway.
The guys at Ford had no idea what I was talking about when I tried to get the plug kit, but I know they have it because I've seen it.
