Out50Stang
· Registered
Discussion starter · #1 ·
I was thinking maybe Caster/Camber plates (so I can change my camber when I auto-x) and then a Panhard Bar
Also does a Panhard bar help plant the tires when cornering? or does it only stop side to side movement? (I don't think it'd fit with my MAC catback unless someone has tried it :( i can modify though :))
My brakes are almost out of the way, my rear discs will be going on very soon, then I'll be all set in that department, and I don't need anymore power, i'm getting new rear tires next, then I can go for more handling mods
suggestions?
C/C plates are a great purchase. Not only will you have more range on Camber, but the benefit of adjust for more caster (which will give more camber). Another thing to think about is subframe connectors if you dont have them.
Discussion starter · #4 ·
They are still new, when i need new ones i might get Bilstiens or Konis, not in my list of priorities right now
Discussion starter · #5 ·
Should I get a set of Corba R's? I need new rear tires, and was thinking about this now, I can wait on tires until i get new rims, would they help out a significant amount over my 16" Ponies? i have small front tires, getting a different backspacing to move the tires out would be nice so i could fit a wider wheel, anyone?
Rims would be a killer upgrade on my car, I'm thinking some white Cobra R's
