Just installed TFS stage 1 cam. Rest of combo in sig. Had FP at 44psi for best mph w/ combo in sig. Just set it to 38psi. WHat are you other stage 1/ TW guys runnin?
I've got a similar setup...just a different cam...and I run near stock FP. Setups like ours don't require a FP much different than stock, especially with #24 injectors. In other words, I'd try 38-42, vacuum off.
FasterDamnit!--are you running 1.7 rockers with that cam? Also, did you degree it or just stick it in dot to dot. If you did degree it how did you put it in? Im anxious to see how the cam and injectors helped out your already very strong running combo.
First off- How 'bout those Gamecocks! Come from behind victory over Kentucky!
Yep- 1.7's and runs great! No degreeing- dot to dot. I will have track times this weekend. See the TFS stage 1 cam reviews post for the post-JLdrive report...
