what are your stock bottom end h/c/i combo's running?
997 views 14 replies 14 participants last post by  Fast Orange
#1 ·
let me know your combo and times please 1/8 mile times if possible thanks a lot.
#3 ·
first threadin drag race section is n/a stock bottom ends "its a sticky"
#5 · (Edited)
167,xxx on the short block.
Ported/Polished E7's, E cam, TFS street intake
first time at the track with et streets i pulled off a 13.258@102.73
my launch was horrible, and my shift points were low.
60 ft was a 1.805
12's are very possible with my combo, i just need to drive it like i stole it.
This year my goal with a rebuilt T-Lok is 12.7's-12.9's, anywhere in there and I will be happy. Then it is time to spray and get some low 12's high 11's.
#6 ·
when I first got my 90' coupe all it had was a cobra intake,bcam,shorties with H pipe and flows and ran a 8.2@78 mph on motor and went 7.6@88mph on a 100 shot dry nitrous kit! oh and thay was on ET streets though?
#7 ·
11.64 @118
1/8 was like a 7.3 @ 90-93mph
STOCK SHORT Block <-----Still in car
AFR 165's
Holley intake
75mm TB
80mm Mass Air
AFM N51-P CAM
30 # injectors
AFM Power Pipe
BBK Longtubes
4.30's
Tremec 3550
26X10-15 Slicks
Valve springs took crap and then I sold the H/C/I combo and I have STOCK E7's and STock Cam and intake and run consistant 12.5's /8.0's
Greg
#13 ·
Stock bottem end, stock cam, stock heads with valves, Cobra intake and bolt ons, on a stock suspension...
1.691 60'
7.941 @ 85.89
#14 ·
Flat tappet 565" lift split duration nitrous grind on 289 heads with a Victor JR and holley 600dp. I've only run it on the 2.73 gears. It cut a 2.01 sixty and I only had to shift once to run an 8.4 at 85mph in second, lol. I'm shooting for sevens on this combo when I get everything dialed in before the spray.
For informations sake, I know of a stock shortblock car around here that ran 7.2-7.3 on just a H/C/I setup.
