I’m upgrading and thinking of running a Holley terminator. Don’t need a trans controller because I’m swapping to a manual. Is The terminator the best option on the market?
1996 bronco. Currently a 351w. AFR 185 heads. Edelbrock victor efi manifold. Headers. Custom cam from Ed. 217/223 110 lsa. Zf5 manual swap.for what? What are your mods and future plans. The Holley is expensive and supports auto tune for fuel (VE), Pro-M is the cost of a new born and supposedly requires no tuning... PimpXS supports auto tune for VE and is the least expensive stand alone. Quarterhorse and a stock computer is the cheapest option, does have auto tune but if you use TunerPro it has histograms that tell you what changes to make to the maf curve and a few other tables. Anything requiring tuning is going to require time and patience while you learn how to tune.
Makes no difference, speed density will compensate via AFR , manifold pressure etc. All ecu’s use the same basic principles (AFR, MAP, IAT etc). MAF adds additional input via an estimate of volumetric air flow or as ProM refers to load. ProM major emphasis is based on volumetric air flow, MAP is manifold pressure. Both rely on lambda aka O2 sensors for real-time adjustment.So I need some input from guys. I'm leaning towards the Pro M but the under the advice from multiple tuners and a tuner friend, they recommend the Holley Terminator.
How would speed density from the holley play with the multiple changing altitudes. I live literally at sea level but will be taking the truck up into the mountains. Wouldn't speed density potentially need some adjustments that MAF would do automatically?
Who is that?This is what they recommended to me.
