How much does this take off the car?
Stock 2003 Cobra Convertible Parts | Weight (lb) |
K-member | 52.25 |
Front control arms | 14.5 each |
Coil springs | 9.76 each |
Front spring isolators (all 3 pieces) | 1.1 per side |
Upper strut mounts | 2.52 per side |
Steering rack bushings | 0.414 per side |
Outer tie rod-ends | 1.27 each |
Total | 111.4 |
MM Parts for Mod-motor SN95 | Weight (lb) |
MM K-member | 39.5 |
MM Tubular Front Control Arms | 8.445 each |
Hypercoil 2.5" springs (8" x 425lbs/in) | 3.41 each |
MM Caster Camber Plates | 3.125 per side |
MM Coil-over Kit (for Koni) | 1.0 per side |
MM Steering Rack Bushings | 0.187 per side |
MM Outer Tie-Rod End Bumpsteer Kit | 1.47 each |
Total | 74.8 |
