Collected from a few sources:
Water Pump Bolts:
The quickest and easiest way to get the proper timing cover bolts and water pump bolts is to buy two kits from
www.totallystainless.com.
Timing Chain Housing Kit 302 EFI 12 pt stainless. #6-0847
Water Pump Kit 302 EFI Through '93 12 pt stainless. #6-0931
The above are just bolts, no special studs for accessories
TotallyStainless.com does not sell a water pump kit for 94/95 5.0L.
If the prices above are a bit steep you can piece them together with the information below:
Autozone carries 3 of the odd sizes, which includes 2 studs and one long bolt.
http://www.autozone.com/selectedZip,.../selectZip.htm
The Autozone part number is 23744.
Bolt Dimensions for Autozone (Motormite Inc.) 23744 bolts:
Ford/Lincoln/Mercury Cars & Trucks 3.8L, 4.6L, 5.0L, & 5.8L. Includes 1 bolt and 2 studs.
Bolt Size: 5/16"-18 x 5",
Stud Size: 5/16"-18 x 3/8" x 16 x 5-3/8" and 5/16"-18 x 3/8"-16 x 3-7/16".
Torrie at
www.fastpartsnetwork.com can get you many of the bolts.
More measurements of the water pump/timing cover bolts:
Here are some specs on the OEM fasteners, going clockwise looking at the
front of the engine, starting at the lower passenger side:
All threads are 5/16-18 pitch except for the stud portion of #6-9
which is 3/8-16
#1 Stud/Bolt, OAL 3-5/16, UHL 2.25
Bolt threaded 1", shank 1.25 (1 + 1.25 = 2.25" UHL)
Flange head .25", 5/16-18 stud thread = 13/16"
1 + 1.25 + .25 + 13/16 = 3-5/16" OAL
Drive size is 1/2"
Notes: This bolt/stud clamps the TCC to the block, retains the
timing tab,
and the stud retains the support bracket for the AIR pump,
accessory nut is 5/16-18, 1/2" drive (not a flange nut, but
could be)
#2 Stud/Bolt, OAL 3-1/16, UHL 2.25
Bolt threaded 1", shank 1 (1 + 1 = 2" UHL)
1 + 1 + .25 + 13/16 = 3-1/16" OAL
Drive size is 1/2"
Notes: Same as #1, but the shank is .25" shorter. This bolt/stud
clamps the
TCC to the block, and retains the timing tab. Stud may be unused
#3 Bolt, OAL 4-1/16, UHL 3-7/8
Bolt threaded 1", shank 2-7/8 (1 + 2/7/8 = 3-7/8" UHL)
Standard head 3/16"
1 + 2-7/8 + 3/16 = 4-1/16" OAL
Drive size is 5/8"
Notes: Clamps water pump to TCC and TCC to block
#4 Same as #3
#5 Bolt, OAL 2-7/8, UHL 2-11/16
Bolt threaded 1", shank 1-11/16 (1 + 1-11/16 = 2-11/16" UHL)
Standard head 3/16"
1 + 1-11/16 + 3/16 = 2-7/8" OAL
Drive size is 5/8"
#6 Stud/Bolt, OAL 3-7/16, UHL 1-15/16
Bolt threaded 1", shank 15/16 (1 + 15/16 = 1-15/16" UHL)
Standard head 3/16", 3/8-16 stud thread = 1-5/16"
1 + 15/16 +3/16 + 1-5/16 = 3-7/16" OAL
Drive size is 5/8"
Notes: Stud retains accessory, accessory flange nut is 3/8-16,
9/16 drive
#7 Same as #6
#8 Stud/Bolt, OAL 5-5/16, UHL 5-1/16
Bolt threaded 1", shank 2-7/8 (1 + 2-7/8 = 3-7/8" UHL)
Standard head 3/16", 3/8-16 stud thread = 1-1/4"
1 + 2-7/8 +3/16 + 1-1/4 = 5-5/16" OAL
Drive size is 5/8"
9/16 drive
#9 Stud/Bolt, OAL 6-1/2, UHL 5-1/16
Bolt threaded 7/8", shank 4-3/16 (7/8 + 4-3/16 = 5-1/16" UHL)
7/8 + 4-3/16 + 3/16 + 1-1/4 = 6-1/2" OAL
Drive size is 5/8"
9/16 drive
#10 Bolt, OAL 2-1/4, UHL 2
Flange head 1/4"
1 + 1 + 1/4 = 2-1/4" OAL
Drive size is 1/2"
Notes: Clamps TCC to block
#11 Same as #10
#12 Bolt, OAL 1-1/8, UHL 7/8
Bolt threaded 7/8", no shank (7/8 + 0* = 7/8" UHL)
Flange head 1/4"
7/8 + 1/4 = 1-1/8" OAL
Drive size is 1/2"
Notes: Clamps TCC to block (top, near intake)
#13 Same as #12
Ford studs use 5/16” on the engine side and 3/8” studs on the accessory side.
From Helmut Roner for timing cover/water pump bolts for no p/s and no a/c:
Lowes Hardware:
One 5/16 x 5½ inch @ $.47, Item # 55819.
Six 5/16 x 2 inch @ $.16 each, Item # 63319.
Three 5/16 x 4 inch @ $.28 each, Item # 63322
One 5/16 x ? inch @ $. , Item # ?????
The last one I typed I don't have, yet. It should be 2-3/4 to 3 inches long. I bought a 2½ and not much of the threads go far enough into the timing cover. It's for the bolt hole that is between the two water ports on the upper left of the water pump. I'll have that info later tomorrow.
The bolts for the water pump pulley to be used without a belt-driven fan are 5/16 x 3/4 24-thread. The two rearmost cover bolts which bolt the cover to the block (not shown) are 5/16 x 3/4 inch. I am scavenging those from an ARP bolt kit that I have which can't be used with late model timing covers. Only a few from the kit could be used as the kit was designed for older model 289/302/351W timing covers.
