What kind of tuning can I do with an Auto car besides the shift points?
i would like to get some opinions on this too...i have an auto 03, and have heard 26rwhp with the 91 tune..sounds very far fetchedWell I knew about the fuel and rev limiter I forgot to mention them but the timing I knew about but I dont know what I can change it to. Also what gains would I get with changing the timing and running 91 octane?
I would be surprised if it was that much. I'm not sure on the XCAL, but normally there is a set range you can adjust the timing or fuel to.i would like to get some opinions on this too...i have an auto 03, and have heard 26rwhp with the 91 tune..sounds very far fetched
You don't have to pull the fuses but it is good practice. You don't want the battery quitting part-way through a flash or you will foul up the PCM and/or the XCal. SCT suggests hooking up a trickle charger to the battery but this is a little over the top, imo.Can anyone post up a copy of the pages for the XCal2 that tell you which fuses to remove and what the start procedures are when tuning. Like the whole plug in then turn key. Basically the starting instructions. I got a used XCal2 but no manual with it so I just need these parts. Also anyone know where I can buy one of if someone could just make a copy for me that would be great thanks.
