TRICK FLOW STAGE 2 CAM WITH STOCK PISTONS?
12K views 8 replies 8 participants last post by  kiznole
#1 ·
ANYONE RUNNING THE STAGE 2 TRICK FLOW TRACK HEAT CAM WITH A TRACK HEAT OR TWISTED WEDGE HEAD AND STOCK PISTONS? WILL IT CLEAR? I DONT WANNA BUY THE CAM AND CLAY THE PISTONS IF I KNOW IT WONT CLEAR. ANYONE RUNNING THIS COMBO? IM NEW HERE THANK YOU IN ADVANCE.
#2 ·
man i've heard it doesn't clear .... but i've never put one in or ever even took the engine down that far ... but that's the word from what i've heard ... and if* it doesn't clear ... well then u can just notch u're piston's a lil bit and wha~laa .. u're running a stage 2 cam ;-D but then again i'm not sure so hopefully someone else will speak up on this??? check out my thread .. "trick flow topic" .. it's got a lotta stuff in there u might be interested in reading?? well did the best i can do later
#3 ·
I don't personally run it, but I know of a few people who do and it clears easy. Hopefully someone jumps in here that is running that setup, but don't worry itll clear.
#7 ·
Edelbrock heads and on a 111IC, the intake valve has .100" with EDELBROCK 1.90 heads. Set the cam up as ground, you're probably down to .070, and that's with valves that fit in the reliefs. That was checking it with a mock solid lifter that I use just to check P/V clearance, so it's a lifter pump-up worst case scenario kindof test.
