Last week I assembled my freshly rebuilt 302 and dropped it back in the car. After getting everything back together, it fired up and idled for about 5 minutes with no issues, but I didn't have my cooling fan connected so I shut it off as soon as it got up to about 190*. Yesterday I finally got the fan hooked up and was letting it idle in preparation for taking the car on its maiden drive. Everything was good, but just as it got up to temp it started puking coolant all over the ground from somewhere behind the front accessories.
It was hard to tell where the leak was coming from, but from the best I could see it was from the thermostat housing. So I pulled it off, cleaned it up, put a new gasket on it, and reassembled. The moment I started refilling the radiator (with engine off and radiator cap not installed), it started leaking again. I got a mirror and flashlight under the thermostat housing and it appeared to be the thermostat again, so once again I pulled it apart, and even bought a new housing in case the old one was warped or something. At that point I realized I had the thermostat in backwards, and unfortunately I didn't pay attention to the orientation of the thermostat when I pulled it out the first time. I inspected the thermostat housing and intake and couldn't see anything wrong, and figured that the backwards thermostat may have caused the housing to not fully seal against the intake. So I put the thermostat in the correct direction with the new housing and a new gasket, bolted it back up, and.... same problem. Leaking like a sieve when just filling up the radiator.
I decided to dig around further and got under the car, and I then saw coolant leaking steadily from the bottom passenger side of the timing cover gasket. It appears to be coming from the bottom, not the top, but it's possible it's trickling down or spraying somehow.
First, I'm trying to determine how this happened. The engine has literally less than 15 minutes of run time on it. As I said before, I'm wondering if I initially had the thermostat in backwards and that possibly caused the pressure to build up, and the timing cover gasket was the weakest link? I installed the gasket dry, and in the course of researching this problem I've seen that I should have used RTV, so maybe that contributed. Any other theories? Obviously I don't want to do this again.
Now I have to replace the gasket. I'm first going to pull off the front accessories to get a better view of the timing cover and maybe narrow down the problem. My main concern is that I'm using the Ford one piece oil pan gasket with steel insert. Most timing cover sets come with cork pieces so you can cut off the existing oil pan gasket at the block and then use the cork pieces to mate to the cover, but I don't think that's an option with my steel core gasket. I'm considering lifting the engine and slightly dropping the oil pan at the front so the timing cover won't "push" the pan gasket when mating to the block, but that's a pain. Any other suggestions? I know I'll need to RTV all the corners where everything mates to each other.
